TeknoJnky
Feb 03, 2012Hero
dropbox installer
does this addon automatically install the latest dropbox linux release, or only a particular version? does the dropbox linux release update itself, or is it required to pay for another 'dropbox ins...
btaroli
Feb 13, 2012Prodigy
Well, I've had a look through the startup scripts and config and I do definitely see a problem, but unsure of the cause. One this is true... up- or downgrading the firmware will not itself cause the issue. Rather, simply /restarting the NAS/ will cause it.
The init.d script expects the file /c/.dropbox-dist/run_dropbox.sh to exist, and it doesn't. Strangely, it does exist in two different /c/.dropbox-dist-old-* directories, but not in the current one. Very odd. Wonder why... But whatever is happening during install obviously doesn't run the normal startup sequence, or it would fail. So instead it just lurks waiting for a restart to happen.
