TeknoJnky
Feb 03, 2012Hero
dropbox installer
does this addon automatically install the latest dropbox linux release, or only a particular version? does the dropbox linux release update itself, or is it required to pay for another 'dropbox ins...
btaroli
Feb 13, 2012Prodigy
mdgm wrote: Actually the remove.sh script like the install.sh script removes the /c/.dropbox-dist directory. It must be dropbox itself that creates the old directories.
Well the install.sh script adds the run_parts.sh script to the /c/.dropbox-dist folder during installation. You can copy the file from /c/.dropbox-dist-old to /c/.dropbox-dist. The current version of the script was modified early November 2011.
All I can tell you is that I'm getting inconsistent behavior with respect to this and your read of the script. What I do wind up seeing is the following:
drwxr-xr-x 4 admin admin 4096 2012-02-13 18:16 .dropbox-dist
drwxr-xr-x 4 yang users 4096 2012-01-18 11:01 .dropbox-dist-old-d5xe2o
drwxr-xr-x 4 admin admin 4096 2012-02-13 16:15 .dropbox-dist-old-F2a6H6
drwxr-xr-x 4 admin admin 4096 2012-02-13 13:12 .dropbox-dist-old-GLc4LV
I have had to cleanup many older "dist-old" folders in the past, and have no idea why it would even leave these sitting around. The .dropbox-dist above also didn't have a run_dropbox.sh in it until I copied one from one old "dist-old" folders, after comparing them and finding them identical. I've no idea why it's doing this... I'm just reporting the behavior.
During install, the addon reports itself as:
Version: 1.2.49-rnx86-0.2.25
Date: Wed Jan 11 15:23:30 2012
