TeknoJnky
Feb 03, 2012Hero
dropbox installer
does this addon automatically install the latest dropbox linux release, or only a particular version? does the dropbox linux release update itself, or is it required to pay for another 'dropbox ins...
AMRivlin
Apr 08, 2012Apprentice
AMRNAS:~# ps -ef | grep dropbox
admin 3519 1 0 21:47 ? 00:00:00 /bin/bash /c/.dropbox-dist/run_dropbox.sh /c/.dropbox-dist/dropbox admin /c
admin 3523 3519 0 21:47 ? 00:00:00 /c/.dropbox-dist/dropbox
root 8457 3451 0 22:00 pts/0 00:00:00 grep dropbox
AMRNAS:~# at /c/.dropbox-dist/VERSION
syntax error. Last token seen: /
Garbled time
AMRNAS:~# file /c/.dropbox-dist/*
/c/.dropbox-dist/ACKNOWLEDGEMENTS: ASCII English text
/c/.dropbox-dist/array.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/binascii.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_bisect.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/bz2.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_cn.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_hk.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_iso2022.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_jp.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_kr.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_tw.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/collections.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/cPickle.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/cStringIO.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_ctypes.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/datetime.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_dbus_bindings.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_dbus_glib_bindings.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/dropbox: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.8, stripped
/c/.dropbox-dist/dropboxd: POSIX shell script text executable
/c/.dropbox-dist/fastpath.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/faulthandler.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/fcntl.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_functools.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/grp.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_heapq.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/icons: directory
/c/.dropbox-dist/itertools.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libbz2.so.1.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libcrypto.so.0.9.8: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libpng12.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libpopt.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/library.zip: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.8, stripped
/c/.dropbox-dist/_librsync.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/librsync.so.1: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libssl.so.0.9.8: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libstdc++.so.6: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_baseud-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_baseud_net-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_baseud_xml-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_gtk2ud_adv-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_gtk2ud_core-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_gtk2ud_qa-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libz.so.1: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_locale.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_lsprof.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/math.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_multibytecodec.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/netifaces-0.5-py2.5-linux-i686.egg: directory
/c/.dropbox-dist/operator.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/parser.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/pyexpat.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_random.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/README: ASCII English text
/c/.dropbox-dist/resource.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/run_dropbox.sh: Bourne-Again shell script text executable
/c/.dropbox-dist/running: empty
/c/.dropbox-dist/select.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/setuptools-0.6c11-py2.5.egg: Zip archive data, at least v2.0 to extract
/c/.dropbox-dist/_speedups.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/strop.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_struct.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/termios.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/time.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/unicodedata.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/VERSION: ASCII text, with no line terminators
/c/.dropbox-dist/_weakref.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._controls_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._core_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._gdi_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._misc_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._windows_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
