TeknoJnky
Feb 03, 2012Hero
dropbox installer
does this addon automatically install the latest dropbox linux release, or only a particular version? does the dropbox linux release update itself, or is it required to pay for another 'dropbox ins...
WhoCares_
May 11, 2012Mentor
To answer your question first: No that's not possible because that would mean you'd have to enter your Dropbox credentials and there'd have to be some sort of database to be able to tell what credentials to use for what user account on the ReadyNAS. Also, if you unlink a Dropbox, then restart the daemon, it will always calculate a new hash for the device to be linked. There's no (known) way to tell the daemon to re-use an already known hash for the device. As fas as I know this is "as designed" to make it possible to run different instances for different users on the same hardware. I'd have to try again with a standard dropbox install but I believe the behavior is the same there.
-Stefan
-Stefan
