fifer55
Jul 06, 2013Apprentice
DropBox: Not able to link account
Hello everyone, I recently purchased the following addon - Dropbox (vInstall-rnx86-1.0.1): viewtopic.php?f=48&t=58647 It was installed on a newly updated (factory reset) ReadyNas Pro Business Edit...
fifer55
OK, seems that there is someone in Turkey that also had this problem:
https://www.pardus.org.tr/forum/-/messa ... _480178929
(Google Translate to the rescue)
There are a couple of places that say to download the Debian (.deb) 32-bit from:
https://www.dropbox.com/install?os=lnx
And replace the following directories that are installed with add-on:
/c/.dropbox/
/c/.dropbox-dist/
with the ones that are installed from the above link.
Hopefully this works...
/c/.dropbox/
/c/.dropbox-dist/
- Apr 16, 2020Retired_Member
