fifer55
Jul 06, 2013Apprentice
DropBox: Not able to link account
Hello everyone, I recently purchased the following addon - Dropbox (vInstall-rnx86-1.0.1): viewtopic.php?f=48&t=58647 It was installed on a newly updated (factory reset) ReadyNas Pro Business Edit...
fifer55
Jul 07, 2013Apprentice
WhoCares? wrote: Wow, there may well be some problems interacting here.
Tell me about it! Hopefully it is nothing I am doing, but I am known to mess things up pretty bad :oops:
WhoCares? wrote: First, as mdgm suggested, there are some browsers (especially on Windows but I don't want to rule out the Mac here although I've never run into the problem) that won't reflect status changes properly. IE is the major source of problems here but older versions of Firefox did show that problem too.
Not using IE and my infrastructure is OS X-centric. Just diving into Linux thanks to ReadyNas. The status changes do reflect, from what I can tell. For split seconds, the global user daemon starts, then the web browser refreshes and the daemon stops. Then nothing. I am also running the latest version of Firefox and Safari. Although I am running a few Firefox plugins, but I doubt that is the issue, since status do update on both Safari and Firefox.
WhoCares? wrote: Next, the scripts managing the different Dropbox daemons are meant to run under the "admin" account. By manually starting/stopping/installing stuff there's a good chance that the ownership of some files needed by the web interface and the daemons has changed which in turn could prevent the whole system from functioning properly.
I initially tried installing everything as designed, using Frontview's add-on install page. When the Global user daemon was not starting, little by little I started doing things manually. However, the majority of my SSH is for checking and verifying stuff, until my last attempt.
WhoCares? wrote: What would be interesting to see is the contents of the /tmp directory. There should be some files that contain the logs of the various deamons talking to the Dropbox master server. If those aren't created or contain nothing the starting/stopping/authenticating will fail.
I think you are talking about the "dropbox.admin" file? If not, which one's are you talking about so I can show you. Anyway, here are the current contents of the /tmp directory:
ProBiz-NAS:/tmp# ls -la
total 1268
drwxrwxrwt 5 admin admin 4096 2013-07-07 06:25 .
drwxr-xr-x 23 root root 4096 2013-07-06 22:58 ..
drwxrwxrwx 2 admin admin 4096 2013-07-06 23:40 addons
-rw-r--r-- 1 root root 12 2013-07-04 22:11 .dhcp_server
-rw-r--r-- 1 admin admin 0 2013-07-07 00:09 dropbox.admin
-rw------- 1 admin admin 1118 2013-07-07 00:09 dropbox_errorZLfGLO.txt
-rw-r--r-- 1 root root 0 2013-07-05 10:42 errors_001.log
-rw-r--r-- 1 root root 0 2013-07-05 08:56 group.16698
-rw-r--r-- 1 root root 0 2013-07-05 01:14 group.8976
drwxrwxrwt 2 root root 4096 2013-07-04 23:37 .ICE-unix
-rw-r--r-- 1 root root 935 2010-04-22 21:57 istat.conf
-rwxr-xr-x 1 root root 1155175 2012-11-23 10:57 istatd
srwxr-xr-x 1 admin admin 0 2013-07-06 22:58 istatd.sock
srw------- 1 root root 0 2013-07-06 22:58 pureftpd.sock
-rw-r--r-- 1 admin admin 98304 2013-07-06 23:53 update_file
drwxrwxrwt 2 root root 4096 2013-07-04 23:37 .X11-unix
WhoCares? wrote: Generally it's a very *bad* idea to try to fix things manually using the "root" account. This is more likely to break things than to fix them.
Yeah, I know! Especially if you don't know what you are doing, like me :oops: However, I am learning a lot, which is always fun. Luckily, there is not super critical data on this box. This is all my work stuff really. My other ReadyNAS has all my critical data, which is backed up by CrashPlan. But I digress...
WhoCares? wrote: The same is true for the global /c/Dropbox share. As with other parts of the add-on, it is crucial that the ownership as well as the permissions of that directory match what is expected by the daemons and the Frontview tools. Manually creating the directory is more likely to create problems instead of fixing them.
The /Dropbox share was created within Frontview's share's tab. I made sure to follow instructions as much as possible. I figured that the permissions all have to be the same. If not, the instructions would say to SSH into the box. I have not tampered with the permissions of the /Dropbox share. Here they are currently for reference:
ProBiz-NAS:/# ls -l
total 76
lrwxrwxrwx 1 root 16 2013-07-05 01:14 addons-config -> /c/addons-config
lrwxrwxrwx 1 root 9 2013-07-04 13:14 backup -> /c/backup
drwxr-xr-x 2 root 4096 2013-07-04 13:03 bin
drwxrwxrwx 20 root 4096 2013-07-07 00:09 c
drwxr-xr-x 18 root 5040 2013-07-06 22:58 dev
lrwxrwxrwx 1 root 10 2013-07-05 08:58 Dropbox -> /c/Dropbox
drwxr-xr-x 73 root 4096 2013-07-06 22:57 etc
lrwxrwxrwx 1 root 14 2013-07-05 01:49 fortressftp -> /c/fortressftp
drwxr-xr-x 6 admin 4096 2013-07-04 13:03 frontview
drwxr-xr-x 3 root 4096 2013-07-04 13:03 home
drwxr-xr-x 2 root 4096 2007-09-07 10:53 initrd
lrwxrwxrwx 1 root 9 2013-07-05 01:30 janftp -> /c/janftp
drwxr-xr-x 13 root 4096 2013-07-04 13:03 lib
drwxr-xr-x 2 root 4096 2013-07-04 13:03 lib64
drwx------ 2 root 16384 2013-07-04 13:03 lost+found
drwxr-xr-x 2 root 4096 2006-10-28 07:06 mnt
drwxr-xr-x 2 root 4096 2010-05-15 02:29 opt
dr-xr-xr-x 97 root 0 2013-07-06 22:57 proc
drwxrwxrwt 3 root 0 2013-07-07 09:23 ramfs
drwxr-xr-x 3 root 4096 2013-07-06 22:57 root
drwxr-xr-x 2 root 4096 2013-07-04 13:03 sbin
drwxr-xr-x 12 root 0 2013-07-06 22:57 sys
drwxrwxrwt 5 admin 4096 2013-07-07 06:25 tmp
drwxrwxrwt 2 root 40 2013-07-06 22:57 USB
drwxr-xr-x 11 root 4096 2008-09-20 04:27 usr
drwxr-sr-x 15 root 4096 2009-11-20 06:29 var
lrwxrwxrwx 1 root 10 2013-07-05 01:14 webroot -> /c/webroot
WhoCares? wrote: The Dropbobx add-on should create all needed directories for you and if it doesn't that points to a more basic problem preventing the add-on from installing properly.
-Stefan
It does, here is the current /c/ permissions and users for reference:
ProBiz-NAS:/# ls -la /c/
total 108
drwxrwxrwx 20 root root 4096 2013-07-07 00:09 .
drwxr-xr-x 3 root root 4096 2013-07-05 00:10 addons-config
-rw------- 1 root root 8192 2013-07-07 00:09 aquota.group
-rw------- 1 root root 8192 2013-07-07 00:09 aquota.user
drwxrwxrwt 2 nobody nogroup 4096 2013-07-04 13:13 backup
drwx------ 3 admin admin 4096 2013-07-07 00:09 .dropbox
drwx-----T 3 nobody nogroup 4096 2013-07-06 23:35 Dropbox
drwxr-xr-x 5 admin admin 4096 2013-07-07 00:04 .dropbox-dist
drwxr-xr-x 5 admin admin 4096 2013-07-06 23:51 .dropbox-dist.2.2.8
drwx--S--T 36 fortress fortress 4096 2013-07-06 21:01 fortressftp
drwxrwxrwx 2 admin admin 4096 2013-07-05 00:15 .gitscm
drwxr-xr-x 5 admin admin 4096 2013-07-06 21:00 home
drwxr-xr-x 2 root root 4096 2013-07-04 13:13 .iscsi
drwx-----T 2 jan jan 4096 2013-07-05 02:32 janftp
drwx------ 2 root root 16384 2013-07-04 13:12 lost+found
drwxrwxrwx 2 admin users 4096 2013-07-05 02:14 media
drwxr-xr-x 7 admin admin 4096 2013-07-05 00:09 .puremgr
drwxr-xr-x 6 admin admin 4096 2013-07-06 22:58 .pyload
drwxr-xr-x 6 root root 4096 2010-05-15 02:23 .rfw
drwxr-xr-x 2 ReadyNAS root 4096 2013-07-04 13:13 .timemachine
drwxr-xr-x 3 root root 4096 2011-03-29 08:51 webroot
The only directory that is not created is the /c/Dropbox for the Global Dropbox user, which is the one I am trying to initialize, with no success. However, I created on Frontview, per instructions.
- Apr 16, 2020Anonymous
