fifer55
Jul 06, 2013Apprentice
DropBox: Not able to link account
Hello everyone, I recently purchased the following addon - Dropbox (vInstall-rnx86-1.0.1): viewtopic.php?f=48&t=58647 It was installed on a newly updated (factory reset) ReadyNas Pro Business Edit...
fifer55
Jul 08, 2013Apprentice
mdgm wrote: Try downloading something from ReadyNAS.com using wget via SSH. Does that work?
WhoCares? wrote: I'm a bit confused about the actual meaning of the error message Dropbox is logging. Together with the problem when displaying available add-ons I'm led to believe that instead of a file system problem we're dealing with a network connectivity problem here. So as mdgm suggested it would be helpful if you could run some connectivity tests from the SSH command line on the ReadyNAS like traceroute www.readynas.com
ping whocares.de
and similar commands with other targets.
-Stefan
Yes guys, all that stuff works. Here are examples:
Pinging different destinations:
root@192.168.1.9's password:
Last login: Mon Jul 8 07:29:54 2013 from 192.168.1.8
Last login: Mon Jul 8 09:16:23 2013 from 192.168.1.8 on pts/0
Linux ProBiz-NAS 2.6.37.6.RNx86_64.2.4 #1 SMP Thu Jul 26 05:00:36 PDT 2012 x86_64 GNU/Linux
ProBiz-NAS:~# cd /c/backup/
ProBiz-NAS:/c/backup# ping www.google.com
PING www.google.com (74.125.239.48) 56(84) bytes of data.
64 bytes from nuq04s19-in-f16.1e100.net (74.125.239.48): icmp_seq=1 ttl=53 time=36.9 ms
64 bytes from nuq04s19-in-f16.1e100.net (74.125.239.48): icmp_seq=2 ttl=53 time=32.0 ms
64 bytes from nuq04s19-in-f16.1e100.net (74.125.239.48): icmp_seq=3 ttl=53 time=22.2 ms
^C
--- www.google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 22.269/30.406/36.937/6.094 ms
ProBiz-NAS:/c/backup# ping whocares.de
PING whocares.de (81.169.185.227) 56(84) bytes of data.
64 bytes from h8399.serverkompetenz.net (81.169.185.227): icmp_seq=1 ttl=46 time=190 ms
64 bytes from h8399.serverkompetenz.net (81.169.185.227): icmp_seq=2 ttl=46 time=189 ms
^C
--- whocares.de ping statistics ---
3 packets transmitted, 2 received, 33% packet loss, time 2001ms
rtt min/avg/max/mdev = 189.030/189.622/190.214/0.592 ms
ProBiz-NAS:/c/backup# ping www.cnn.com
PING cnn-lax-tmp.gslb.vgtf.net (157.166.240.11) 56(84) bytes of data.
^C
--- cnn-lax-tmp.gslb.vgtf.net ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 3999ms
^C
11 packets transmitted, 0 received, 100% packet loss, time 9999ms
ProBiz-NAS:/c/backup# ping www.yahoo.com
PING ds-any-fp3-real.wa1.b.yahoo.com (206.190.36.45) 56(84) bytes of data.
64 bytes from ir1.fp.vip.gq1.yahoo.com (206.190.36.45): icmp_seq=1 ttl=48 time=50.9 ms
64 bytes from ir1.fp.vip.gq1.yahoo.com (206.190.36.45): icmp_seq=2 ttl=48 time=58.1 ms
64 bytes from ir1.fp.vip.gq1.yahoo.com (206.190.36.45): icmp_seq=3 ttl=48 time=45.4 ms
^C
--- ds-any-fp3-real.wa1.b.yahoo.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 45.437/51.533/58.175/5.221 ms
Here is a download using wget:
ProBiz-NAS:/c/backup# wget --no-check-certificate -O - "https://www.dropbox.com/download?plat=lnx.x86" | tar xzf -
--2013-07-08 09:22:55-- https://www.dropbox.com/download?plat=lnx.x86
Resolving www.dropbox.com... 199.47.216.170
Connecting to www.dropbox.com|199.47.216.170|:443... connected.
WARNING: cannot verify www.dropbox.com's certificate, issued by `/C=US/O=Thawte, Inc./CN=Thawte SSL CA':
Unable to locally verify the issuer's authority.
HTTP request sent, awaiting response... 302 FOUND
Location: https://dl-web.dropbox.com/u/17/dropbox-lnx.x86-2.2.8.tar.gz [following]
--2013-07-08 09:22:56-- https://dl-web.dropbox.com/u/17/dropbox-lnx.x86-2.2.8.tar.gz
Resolving dl-web.dropbox.com... 23.21.230.11
Connecting to dl-web.dropbox.com|23.21.230.11|:443... connected.
WARNING: cannot verify dl-web.dropbox.com's certificate, issued by `/C=US/O=Thawte, Inc./CN=Thawte SSL CA':
Location: https://dl.dropboxusercontent.com/u/17/dropbox-lnx.x86-2.2.8.tar.gz [following]
--2013-07-08 09:22:56-- https://dl.dropboxusercontent.com/u/17/dropbox-lnx.x86-2.2.8.tar.gz
Resolving dl.dropboxusercontent.com... 23.21.213.190
Connecting to dl.dropboxusercontent.com|23.21.213.190|:443... connected.
WARNING: cannot verify dl.dropboxusercontent.com's certificate, issued by `/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert High Assurance CA-3':
HTTP request sent, awaiting response... 200 OK
Length: 20772183 (20M) [application/x-tar]
Saving to: `STDOUT'
100%[==========================================================================================================================>] 20,772,183 3.66M/s in 6.9s
2013-07-08 09:23:05 (2.87 MB/s) - `-' saved [20772183/20772183]
Haven't changed anything else or modified anything since yesterday.
Again, thanks guys for your help!!
- Apr 16, 2020Retired_Member
