fifer55
Jul 06, 2013Apprentice
DropBox: Not able to link account
Hello everyone, I recently purchased the following addon - Dropbox (vInstall-rnx86-1.0.1): viewtopic.php?f=48&t=58647 It was installed on a newly updated (factory reset) ReadyNas Pro Business Edit...
fifer55
Sep 17, 2013Apprentice
mdgm wrote: If you download the logs (Status > Logs > Download all logs) and extract the zip contents what does bios_ver.log look like?
07/26/2010 FLAME6-MB V2.0
Also, here is my "network_settings.log" content:
bond0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
inet addr:19.XX.1.9 Bcast:19.XX.1.255 Mask:255.255.XXX.0
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:84841 errors:0 dropped:40 overruns:0 frame:0
TX packets:14825 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:11735594 (11.1 MiB) TX bytes:8622555 (8.2 MiB)
eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1
RX packets:48611 errors:0 dropped:2 overruns:0 frame:0
TX packets:6556 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4278747 (4.0 MiB) TX bytes:3194320 (3.0 MiB)
Interrupt:16 Memory:ff6fc000-0
eth1 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
RX packets:36230 errors:0 dropped:6 overruns:0 frame:0
TX packets:8269 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7456847 (7.1 MiB) TX bytes:5428235 (5.1 MiB)
Interrupt:17 Memory:ff7fc000-0
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:102041 errors:0 dropped:0 overruns:0 frame:0
TX packets:102041 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7086164 (6.7 MiB) TX bytes:7086164 (6.7 MiB)
tunl0 Link encap:IPIP Tunnel HWaddr
NOARP MTU:1480 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
IPV6_ASSIGN_eth0=OFF
IPV6_ASSIGN_eth1=OFF
JUMBO_FRAMES_eth0=0
JUMBO_FRAMES_eth1=0
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION
SPEED_DUPLEX_eth1=AUTO_NEGOTIATION
Settings for bond0:
Link detected: yes
Settings for eth1:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: g
Wake-on: g
Link detected: yes
Settings for eth0:
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 0
Supports Wake-on: g
Wake-on: g
Link detected: yes
bond0:4:eth0,eth1:1
- Apr 16, 2020Retired_Member
