polux400
Jan 25, 2013Aspirant
DVBLink TV Server 4.5.2 (from dvblogic)
Hello, I didn't see any main topic about this add-on, so I decided to create one to to regroup all the informations... Here is the annonce : http://dvblogic.com/en/news/38-dvblink-tv-server-x86-...
gibxxi
May 13, 2013Guide
It may be that the transponder settings for your local transmitter are wrong in DVBLink. If you know what frequencies your chosen transmitter(s) use, you can select those frequencies only using the UK "All Frequencies" list. Selected frequencies in the scan area should be dark grey if memory serves.
CTRL+Click to select multiple frequencies.
