przemek_ch
Aug 10, 2014Aspirant
Dynamic Update Client compilation
Hi I need to install No-IP client http://www.noip.com/support/knowledgeba ... te-client/ I need 'make'. So I've been trying to install make-3.81.tar.gz checking for a BSD-compatible install......
mdgm-ntgr
Aug 10, 2014NETGEAR Employee Retired
Shouldn't you just do the following?:
What version of RAIDiator are you running?
# apt-get update && apt-get install build-essential
