przemek_ch
Aug 10, 2014Aspirant
Dynamic Update Client compilation
Hi I need to install No-IP client http://www.noip.com/support/knowledgeba ... te-client/ I need 'make'. So I've been trying to install make-3.81.tar.gz checking for a BSD-compatible install......
przemek_ch
Aug 11, 2014Aspirant
If I knew that there is something like build-essential I'd use it at first place..
Anyway it worked :)
thanks
Anyway it worked :)
thanks
