fastethernet
Feb 26, 2010Aspirant
Freeradius with PEAP support
Hi All, :D I was running a virtual server with freeradius with PEAP support but since power prices are jumping up I wanted to move all my virtual server services onto my Readynas DUO. I have mana...
Pasadena
Mar 01, 2010Aspirant
fastethernet wrote: Hi Pasadena,
Thanks for the support.
I think I will try and compile my own version from source using QEMU and create a .deb to install freeradius with daloradius for a front end. I'll post my attempts here so you guys can have a crack too. Whilst I'm at it I might well try and set up squid with WCCP support and mysar to view the logs.
Cheers
Fastethernet
Ok, tell me, when you are finished. I tried several forms of freeradius, the older version from Debian and the newest from freeradius.org. Both wont run. One comes with bus error, the other with compiler and lib conflicts... :(
So, if you find a way to use a radius, it would be great! :D
PM me! (and in this forum also, of course, I think, many people are waiting for a solution..)
Pasadena
