fastethernet
Feb 26, 2010Aspirant
Freeradius with PEAP support
Hi All, :D I was running a virtual server with freeradius with PEAP support but since power prices are jumping up I wanted to move all my virtual server services onto my Readynas DUO. I have mana...
WhoCares_
Sep 23, 2012Mentor
Getting RADIUS to work on the ReadyNAS isn't that hard. To bake it into a simple to use add-on is another matter. So, if you're comfortable with doing the config stuff on the command line, providing RADIUS shouldn't be that hard to do (iirc I already did it for someone else, just need to find the binaries)
-Stefan
-Stefan
