ledermann
Oct 10, 2010Aspirant
gitscm: Can't connect to git repo
Hi! I have installed the gitscm add-on and can't get it to work, instead the "git-upload-pack: command not found" message appears. What I have done: - Installed gitscm-addon via FrontView and ...
WhoCares_
Oct 22, 2010Mentor
If I recall correctly, the adding of the path should be automatic for *existing* accounts - but I'm not sure now you mention it. Will check.
-Stefan
-Stefan
