ledermann
Oct 10, 2010Aspirant
gitscm: Can't connect to git repo
Hi! I have installed the gitscm add-on and can't get it to work, instead the "git-upload-pack: command not found" message appears. What I have done: - Installed gitscm-addon via FrontView and ...
ledermann
Oct 22, 2010Aspirant
For the root user the path was already ok. I have added /opt/rfw/bin to the path in /etc/profile, but this doesn't change anything.
Here is a full log to demonstrate the problem:
Hope this helps for debugging. Maybe I'm doing something wrong.
Georg
quattro:~ ledermann$ ssh root@readynas
root@readynas's password:
Linux ReadyNAS 2.6.17.8ReadyNAS #1 Tue Jun 9 13:59:28 PDT 2009 padre unknown
ReadyNAS:~# echo $PATH
/opt/rfw/bin:/opt/rfw/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/bin/X11
ReadyNAS:~# whereis git-upload-pack
git-upload-pack: /opt/rfw/bin/git-upload-pack
ReadyNAS:~# git-upload-pack
usage: git upload-pack [--strict] [--timeout=nn] <dir>
ReadyNAS:~# exit
logout
Connection to readynas closed.
quattro:~ ledermann$ git clone root@readynas:/opt/git/repo.git
Cloning into repo...
bash: line 1: git-upload-pack: command not found
fatal: The remote end hung up unexpectedly
Georg
