ledermann
Oct 10, 2010Aspirant
gitscm: Can't connect to git repo
Hi! I have installed the gitscm add-on and can't get it to work, instead the "git-upload-pack: command not found" message appears. What I have done: - Installed gitscm-addon via FrontView and ...
juntabravo
Feb 06, 2011Tutor
After applying the above changes it functions, however only when accessed using the root NAS account, I applied similar changes to the git user however the same git-upload-pack command not found error persists. The same path issue is exhibited for this user even after creating an similar .bashrc file and .ssh directory with authorized_keys. Has anyone been able to access without using you root? Since multiple people will be accessing and I do not want to give root access to everyone a solution would be helpful.
