ledermann
Oct 10, 2010Aspirant
gitscm: Can't connect to git repo
Hi! I have installed the gitscm add-on and can't get it to work, instead the "git-upload-pack: command not found" message appears. What I have done: - Installed gitscm-addon via FrontView and ...
WhoCares_
Feb 06, 2011Mentor
Most likely you fail because all user accounts on the ReadyNAS are normally created with "/bin/false" as their standard shell program. Try running the EnableUserSSH add-on and see whether this fixes your problem. As an alternative you can set the login shell for those accounts that need access to git to "/bin/bash" using an editor on the command line.
-Stefan
-Stefan
