ledermann
Oct 10, 2010Aspirant
gitscm: Can't connect to git repo
Hi! I have installed the gitscm add-on and can't get it to work, instead the "git-upload-pack: command not found" message appears. What I have done: - Installed gitscm-addon via FrontView and ...
colinb
Feb 13, 2012Aspirant
If I want to access the git repositories with a non-root user, should I connect as the user "git" (which was created when I installed the addon)? If so, do I need to set a password?
EDIT: This didn't occur to me until now -- should I be using the "User" security mode (as opposed to "Share" mode)?
--Colin
--Colin
