Dewdman42
May 20, 2012Virtuoso
Help getting pureftpd working
I have recently purchased and installed Who Care's pureftpd addon. I went into the virtual user manager and created a virtual user, assigned it to one of the NAS uid's, which I guess influences what...
WhoCares_
May 21, 2012Mentor
As it seems the ReadyNAS doesn't support per share mappings using a map_static directive in the exports file. But it should at least allow for setting the anonuid and anongid parameters which together with an all_squash directive should do the trick of rerouting your Mac user ID to the correct one on the ReadyNAS. The major drawback here is that you'd then have to make sure that only your Mac is allowed to access sensible shares and even then all users on the Mac would gain access to your user's shares on the ReadyNAS. NFS just isn't perfect ;)
-Stefan
-Stefan
