JimBeen
Mar 15, 2011Guide
How to automate HDParm tweak?
Hi, I've fitted a couple of Seagate ST32000542AS in my NV+ and they work fine. The only problem was the annoying clicking sound they made every so often. After some Googling I've fixed that too, af...
Etz
Mar 24, 2011Aspirant
JimBeen wrote: No one else got a clue?
Either for a later firmware or where is appropriate to place the commands?
Use shell script and cron/crontab to run that script, because as far as I know Readynas doesnt use and ignores startup scripts, at least most of them. :roll:
