JimBeen
Mar 15, 2011Guide
How to automate HDParm tweak?
Hi, I've fitted a couple of Seagate ST32000542AS in my NV+ and they work fine. The only problem was the annoying clicking sound they made every so often. After some Googling I've fixed that too, af...
JimBeen
Mar 31, 2011Guide
Thanks for that, I've given it a go and restarted the box. I VPN'd in from work to do it, so I don't know if it's taken effect but the device restarted just fine so it looks promising. I'll get back to the forum with the results ASAP in case anyone else if thinking of doing the same with theirs.
Talking of others, for their information I also copied those files to backups ones before I modified them, just in case...
cp /etc/frontview/addons/addons.conf /etc/frontview/addons/addons.conf.old
cp /etc/default/services /etc/default/services.old
Then editted as super-poussin instructed:
vi /etc/frontview/addons/addons.conf
Using instructions here http://www.cs.colostate.edu/helpdocs/vi.html because only sadist know the vi commands off the top of their head ;)
And then:
vi /etc/default/services
To do the last bit. Typed reboot, hit enter and crossed my fingers.
Again, thanks to everyone especially super-poussin for their help.
And then:
