JimBeen
Mar 15, 2011Guide
How to automate HDParm tweak?
Hi, I've fitted a couple of Seagate ST32000542AS in my NV+ and they work fine. The only problem was the annoying clicking sound they made every so often. After some Googling I've fixed that too, af...
dsm1212
Mar 02, 2013Apprentice
For future reference, an addon is really overkill. If you already have ssh access, then /etc/hdparm.conf should work for this unless netgear has done something odd. Google "man hdparm.conf".
steve
steve
