ScottChapman
Jan 26, 2014Apprentice
how to configure iStat on OS6?
I got iSTat installed and running. But launch button is not active.
It does day what port to use, and what the default password, question is, what is the URL?
I tried http://<NAS>:5109 but get a "null" back.
- super_poussinVirtuosoYep that's 12345 by default as written on the frontview interface
- doylmiGuideHow'd it go? :)
- ScottChapmanApprentice
doylmi wrote: How'd it go? :)
Got it. THanks! - doylmiGuide
doylmi wrote: I'll make sure this is clearer in the next iteration. Will probably prompt for the passcode iStat is detected, but the passcode is missing.
This has been implemented.- ReadyASGuide
I will describe my case I had on RNDP4000 with OS6:
The stat daemon did not started, so I tried to run it manualy:
root@nas:/apps/istat/bin# ./istatd
and I saw the message:
"Could not read configuration from /usr/local/etc/istat.conf: No such file or directory
root@nas:/apps/istat/bin# more istatd"So I copied istat.conf:
root@nas:/apps/istat/bin# cp -p /etc/istat.conf /usr/local/etc/
Since this time there was not problem tu run the stat daemon from UI using ON/OFF switch, but still the main RUN button is inactive.
Iteresting that:
"root@nas:/apps/istat/bin# ps -ef|grep istat
admin 18717 1 0 18:45 ? 00:00:00 /apps/istat/bin/istatd -d -c /etc/istat.conf"I mean "/etc/istat.conf" is as a parameter and "/usr/local/etc/istat.conf" is used in reality? Is the second path hardcoded?
