hqonline
Aug 15, 2013Aspirant
How to get sabnzb to use sickbeard folder-setup ?
Hi, I've installed SABnzbd_0.7.14-sparc and Sickbeard_0.88437-msparc add-ons on my Readynas Duo v1. I've set up my shows in sickbeard and everything downloads fine in sabnzb. But sabnzb won't move...
hqonline
Aug 17, 2013Aspirant
gibxxi wrote: You need to point SABnzbd to the folder containing the post processing scripts you want to use to process your TV shows. On my ReadyNAS it's /c/.sickbeard/scripts. You may need to SSH into the NAS to determine the correct location, but it will be a sub-folder of the /c/.sickbeard/ folder.
You then need to create a category in SABnzbd that will handle your TV episodes when they are downloaded. In this category you will select the "autoprocesstv.py" or "sabtosickbeard.py" script, whichever is displayed in the drop-down menu for post-processing scripts in the category creation screen of SABnzbd.
Finally you'll need to update Sickbeard with the name of the category your using (in SABnzbd) for TV shows.
Sorry if this is all a bit vague, I'm reciting this from memory, as I'm not able to check my configuration right now.
Ok, thanks I'll try this. :D
