Sandshark
Jan 12, 2019Sensei
How to update RAIDiator 4.2.28 Virtual Machine to 4.2.31
I use a RAIDiator 4.2 Virtualbox virtual machine to help answer questions that come from here. ( See RAIDiator-x86-4-2-28-VirtualBox-image-notsupported). In that thread, Chirpa stated that "Firmware...
Sandshark
Jan 12, 2019Sensei
An odd thing I just discovered. After the update, the NAS VM was reporting a hostname based on the MAC address, as is the default. But in Frontview, it still showed what I had named it. Changing it, then changing it back, fixed it only temporarilly. Rebooting brought it back to the MAC based name.
So, I took a look at /etc/hosts and /etc/hostname. At boot, hosts contained both IP addresses (for the two virtual NICs) and the hostname twice on each line. After I edited the hostname.in Frontview, it contained only the IP for the first interface and the hostname once. etc/hostname also contains the right name. I have no clue why it is picking up the wrong hostname at boot nor why it is over-writing /etc/hosts every time. etc/hostname does not seem to do a thing. I changed the content, and it had zero effect but was not overwritten at boot.
- SandsharkJan 13, 2019Sensei
There is an alternative to creating the .vdi with VBoxManage instead of VMDK2VDI (good for those not using Windows).
vboxmanage clonehd "virtualdisk.vmdk" "new-virtualdisk.vdi" --format vdi
Thatt creates the .vdi with a new UUID every time. So, you could even make two copies, one set to the default OS re-install and the other normal. Then just swap between them in the VirtualBox settings.
You can leave off the --format vdi and make a .vmdk clone if you prefer to work with that format.
I also wanted to add that Windows' creation of a Volume Information folder and Recyle Bin when you mount the virtual drive does no harm.
