btaroli
Dec 14, 2011Prodigy
Issue with DropBox 1.2.49 Update
This is on a ReadyNAS Pro 6 running 4.2.19 I first tried applying the new release over 1.2.48 -- the usual approach to updating -- and it seemed the service didn't want to start. So I removed it an...
sphardy1
Dec 14, 2011Apprentice
btaroli wrote:
mdgm wrote: Also references to ".AppleDouble" may possibly indicate that DropBox doesn't work nicely with Netatalk. I don't access the DropBox folder on my NAS via AFP. I use CIFS.
I would have accepted this if it had been an issue with 1.2.48. I only access my NAS user home via AFP. So if /that/ was the problem, then it'd have shown up instantly. No need to wait for an upgrade. ;)
I think you misunderstand my post - the .AppleDouble folders are sync'ed and are then visible via the dropbox web interface, but are not typically visible on your mac which always treats such files as hidden. This is simply a fact - true as of dropbox version 1.2.48 - and not a claim that it may be a cause of the problem you are facing
