btaroli
Dec 14, 2011Prodigy
Issue with DropBox 1.2.49 Update
This is on a ReadyNAS Pro 6 running 4.2.19 I first tried applying the new release over 1.2.48 -- the usual approach to updating -- and it seemed the service didn't want to start. So I removed it an...
WhoCares_
Dec 14, 2011Mentor
btaroli wrote:
sphardy wrote:
btaroli wrote:
mdgm wrote: Also references to ".AppleDouble" may possibly indicate that DropBox doesn't work nicely with Netatalk. I don't access the DropBox folder on my NAS via AFP. I use CIFS.
I would have accepted this if it had been an issue with 1.2.48. I only access my NAS user home via AFP. So if /that/ was the problem, then it'd have shown up instantly. No need to wait for an upgrade. ;)
I think you misunderstand my post - the .AppleDouble folders are sync'ed and are then visible via the dropbox web interface, but are not typically visible on your mac which always treats such files as hidden. This is simply a fact - true as of dropbox version 1.2.48 - and not a claim that it may be a cause of the problem you are facing
'cept the problem is that I can observe that 1.2.48 /didn't/ sync them to dropbox, even if present. Observable and repeatable.
I've been trying this back and forth with 1.2.48 and 1.2.49 for hours now and the behavior of both versions for me is exactly the same:
If you access a Dropbox that is on your local hard drive on a Mac, the .AppleDouble folders won't be synced, that's correct. However, if you access a Drobox folder that is shared using AFP from a Mac, the .AppleDouble folders will be created in the share *and* will be replicated. I could reproduce this for 1.2.48 and 1.2.49. Now if you happened to have a local Dropbox with local .AppleDouble folders, the Dropbox daemon would of course delete/update/replace your local copies because of that replication.
So my conclusion right now is that somehow the Dropbox daemon detects that it is running on a Mac and if it is, it won't replicate .AppleDouble and what other special stuff the Mac creates TO the network. However, since the ReadyNAS isn't a Mac, the daemon there will detect those files/dirs as soon as they are created through an AFP client connection and then replicate them. Now if you access the Dropbox using multiple Mac clients you will most likely receive a constant stream of update/delete/create messages.
But right now I don't see how this is a problem caused by the add-on , nor is there a chance to fix it through it. And as I said: for me even 1.2.48 behaves that way.
Now I may totally misunderstand the problem here, so if I do please give me more feedback so I can better understand and mirror the setup.
-Stefan
