boz0
Oct 13, 2010Aspirant
JDownloader quick howto
Technically, this isn't an addon, but since it's about an app that's been requested several times as an addon, I figure this post has its place here. Since JDownloader isn't yet a client/server app...
boz0
Dec 12, 2010Aspirant
cholo12 wrote: really nice how to, is there a way to get jdownloader running on readynas duo? I know that has a different processor architecture but maybe it can run under sablevm, you seem to be really skilled on linux use and besides my knoweledge is pretty limited maybe you could guide me.
I managed to install sablevm on my duo but I got errors running the script related to unsuported java -Xmx512m, I removed -Xmx512m entries but when I run the script seems to be doing nothing.
thanks in advance for your help. regards.
I'm afraid my knowledge of java virtual machines is rather limited. Maybe you should look in the sablevm documentation to find the correct option for specifying a VM's max memory.
Good luck, and remember that the duo's CPU might be a bit slow to run a somewhat heavy java process. :)
