boz0
Oct 13, 2010Aspirant
JDownloader quick howto
Technically, this isn't an addon, but since it's about an app that's been requested several times as an addon, I figure this post has its place here. Since JDownloader isn't yet a client/server app...
boz0
Dec 12, 2010Aspirant
giovannip wrote:
boz0 wrote: Make sure /usr/bin is in your PATH variable (echo $PATH), and make sure the xbase-clients package is installed (apt-get install xbase-clients).
Thanks this solved the issue! unfortunatly now if I don't keep running xming JDownloader closes .... any workaround on this ?
That's because you're running jdownloader as a client of your xming X server. Shutting down the X server automatically kills any attached clients.
The workaround is to run it inside xvfb instead of attaching it to your X display. Xvfb is a virtual display entirely contained in the readynas' memory. That way, you don't get the jdownloader's usual display, but if you've configured it correctly, you can still access it via the web interface.
