boz0
Oct 13, 2010Aspirant
JDownloader quick howto
Technically, this isn't an addon, but since it's about an app that's been requested several times as an addon, I figure this post has its place here. Since JDownloader isn't yet a client/server app...
coreyinoz
Jan 21, 2012Tutor
First off, thanks boz0 for the great tutorial. I admit that I had to give up and come back a couple of times to bash through all of this (being a Linux novice, some of this was difficult for me to digest).
Anyway - I'm left with just a couple of questions;
Is there anything that can be done on Xming or SSH configuration to speed up the X11 window under Windows 7? I appreciate the point of the tutorial is to go headless and use the web interface, but the full GUI is nice for certain things, and the performance is shite...
Is there any way to specify the user permissions of the saved files in advance? I notice that JD is saving everything as root, which means I can't delete the files from over my SMB share unless I SSH in and update the permissions first... would be nice if I could get downloads to save with wide open permissions up front.
Other than that - it works awesome!
Thanks.
CB
Thanks.
CB
