boz0
Oct 13, 2010Aspirant
JDownloader quick howto
Technically, this isn't an addon, but since it's about an app that's been requested several times as an addon, I figure this post has its place here. Since JDownloader isn't yet a client/server app...
tom_homelinux
Feb 14, 2012Aspirant
i´ve got it running with a virtual X11 display, running fluxbox and then a VNC server in it. So you can access it from everywhere. Additional you can activate and run the web-interface of jdownloader to add new items. everthing can be installed with apt-get or aptitude. my box is a rndu2120 and everything (x11server, vncserver in it and jdownloader) starts automatical after reboot. i´m using for jdownloader a local copy of sun-java-jre 1.6.0 with no errors at jdownloader startup (e.g. funambol linux package, extract and copy the jre1.6 tree into a local directory). openjdk gives me always a lot of errors.
if you are interested, i can send you the config files for autostart
greets
tom
greets
tom
