shadowboxer
Sep 09, 2009Aspirant
LAME add-on
Hi! Does anyone know of any projects to build a Radiator add-on to install LAME on the slimserver software on the ReadyNAS pro. My search on both this and the slimdevices forum have come up short....
atz6975
Nov 22, 2009Guide
MikeMcr wrote: Does this plug-in work with firmware 4.2.7? Doesn't seem to install anything.
Worked here :427 on NVX.
To check : got to settings of Squeezecenter, choose AUdio settings of Player and it should say that lame is correctly installed as as comment on the page.
