mdutton
Nov 19, 2019Aspirant
Legacy Readynas Surveillance - Where can I find it?
I factory defaulted my RN716 to start with fresh disks, but now the original Surveillance app that was there and which I have purchased licences for, is no longer available. This is the version that ...
- Nov 26, 2019
Thanks Stephen.
That file had a million dependency errors. However, I tried apt-get install surveillance and got version 1.4.3-18. It works.
Thanks for the pointer though. It headed me in the right direction.
Mark
Nov 20, 2019Guru - Experienced User
Not sure if this is the final version, but this download link still works: http://apt.readynas.com/packages/readynasos/dists/apps/pool/s/surveillance/surveillance_1.4.3-15_amd64.deb
- mduttonNov 26, 2019Aspirant
Thanks Stephen.
Mark
- StephenBNov 27, 2019Guru - Experienced User
Good to know, as I think some others will likely need this.
Netgear really should host this somewhere, with a prominent note that it needs a license that is no longer offered.
Marc_V: any reason it couldn't be added to the downloads here: https://www.netgear.com/support/product/RNNVR01L-1000S.aspx#download
- Marc_VNov 27, 2019NETGEAR Employee Retired
The App was remove since it was replaced by Milestone Arcus after it was EOL last Sept 2017 but Milestone also ended last July 2018
I think they have not added it anymore since it's EOL. But still available on the repo. I don't think they have plans on putting it back for download since no update was made to it so security vulnerabilities are there already.
HTH
Regards
- Nov 24, 2016Retired_Member
