generic_usernam
Jul 27, 2010Aspirant
"Login failed" with Remote on OS X 10.5.8
I can't log in with ReadyNAS Remote - I just get the growler notification saying ReadyNAS Remote, Login failed. Yet when I click "View Profile" in Remote, it sends me to the website https://remote.re...
RoamyAl
Jul 31, 2011Aspirant
I have the same symptoms: "Login Failed" in the Growl dialog. However, rebooting did not fix this for me.
I'm running OS X 10.7 (Lion), though I had the same issue before upgrading. I'm using all default settings for network configurations, etc. I'm on a home network, not work, so no fancy firewalls would be getting in the way. In fact, I can login and use ReadyNAS Remote from Windows (same PC, dual-boot), no problem. Also, I can log in to the website.
