Felidae
Mar 22, 2017Aspirant
Lost installation CD
HI, My problem is rather silly. After moving from Germany to France I have to reinstall my Nas as the Front view is no longer showing in a correct way( Nas Works 5/5). But.... but the CD may be get...
- Mar 25, 2017
You had a 1.5GB error log for the http/s service that filled up the 2GB root volume. Btw there is newer firmware available than what you are running. The latest firmware is 4.1.15.
mdgm-ntgr
Mar 22, 2017NETGEAR Employee Retired
You don't need a CD. RAIDar is available for download online.
Can you provide a screenshot of what you see?
Which firmware is it running?
- FelidaeMar 22, 2017Aspirant
Hallo,
thanks for your answer.
I've Raidar working. Or I think so
My problem is the Frontview, the dialog Interface.
Here three snaps:
https://www.dropbox.com/s/gpmshvio0yixo6g/Ashampoo_Snap_2017.03.22_14h22m58s_002_.png?dl=0
https://www.dropbox.com/s/r7kxztdjdqy5mkv/Ashampoo_Snap_2017.03.22_14h18m55s_001_.png?dl=0
https://www.dropbox.com/s/y3v504nhlljebh3/Ashampoo_Snap_2017.03.22_14h26m39s_003_.png?dl=0
As youcan see no access.
My second Netgearnas (10400) is working flawlessly
Thanks for any help
Regards
daniel
- mdgm-ntgrMar 22, 2017NETGEAR Employee Retired
Have you tried clearing your web browser cache?
Have you tried a different web browser?- FelidaeMar 23, 2017Aspirant
Hi,
Yes we have cleared the cache.
Many times.
In Chrome as well as in Explorater11 for Windows7.
We have tried the reset (without suppressing Data)
Everything would be good if I ould be able to communicate with the Front View
An idea?
Thanks
daniel
