RaymondBailey
Jul 27, 2018Aspirant
Missing /bin folder (ReadyNAS 600 Pro+ RNDP600U)
While connected via ssh and performing an rsync backup I managed to delete the /bin folder on from the device rather than from the external HDD, however the copy on the external HDD is available.
- Aug 15, 2018
Performing the OS reinstall from the boot menu worked, now the admin menu is reporting a drive in predictive failure (it wasn't before and I only knew via email alert). My understanding it that the drive is hot swappable, please correct me if I am wrong as I do have a replacement on hand.
Jul 27, 2018Guru - Experienced User
You could of course copy the files with the cp command (or use rsync in the reverse direction).
RaymondBailey
Currently the ssh prompt is at the external HDD, so the correct command to execute is?
"cp -a ./bin/. /"
