RaymondBailey
Jul 27, 2018Aspirant
Missing /bin folder (ReadyNAS 600 Pro+ RNDP600U)
While connected via ssh and performing an rsync backup I managed to delete the /bin folder on from the device rather than from the external HDD, however the copy on the external HDD is available.
- Aug 15, 2018
Performing the OS reinstall from the boot menu worked, now the admin menu is reporting a drive in predictive failure (it wasn't before and I only knew via email alert). My understanding it that the drive is hot swappable, please correct me if I am wrong as I do have a replacement on hand.
mdgm-ntgr
Aug 13, 2018NETGEAR Employee Retired
You could try
# touch /.os_update
or
# echo > /.os_update
Then reboot the NAS
Or do an OS Re-install using the boot menu. This should recreate the /bin folder.
RaymondBailey
Aug 14, 2018Aspirant
Doesn't touch reside within the /bin/ folder or am I mistaken?
