RaymondBailey
Jul 27, 2018Aspirant
Missing /bin folder (ReadyNAS 600 Pro+ RNDP600U)
While connected via ssh and performing an rsync backup I managed to delete the /bin folder on from the device rather than from the external HDD, however the copy on the external HDD is available.
- Aug 15, 2018
Performing the OS reinstall from the boot menu worked, now the admin menu is reporting a drive in predictive failure (it wasn't before and I only knew via email alert). My understanding it that the drive is hot swappable, please correct me if I am wrong as I do have a replacement on hand.
RaymondBailey
Aug 14, 2018Aspirant
Doesn't touch reside within the /bin/ folder or am I mistaken?
mdgm-ntgr
Aug 14, 2018NETGEAR Employee Retired
Hmmm. Good point.
In that case you may need to use the boot menu to do an OS Re-install. Though depending how much the system is messed up doing a factory reset and restoring from backup may still be the best way forward.
Though you just need to do anything that creates the /.os_update file (it can be empty)
Even something like
1 > /.os_update
might work. It'd give an error but it'd probably still create the file.
- RaymondBaileyAug 14, 2018Aspirant
Where is this file to reside, I would want to verify the file creation using:
rsync --list-only -v
I am assuming a reboot of the device would then be necessary to complete the process or will this happen or is tht not the case.
In the process of validting my backup copy to the external USB hdd before I loose the ability to mount devices.
- mdgm-ntgrAug 14, 2018NETGEAR Employee Retired
The file would reside in / as indicated by the command I gave. It can be empty and will automatically get removed as part of the OS Re-install (to avoid triggering it again on each subsequent reboot).
The path for that file is deliberately pretty much as simple as it gets. We know that we should always be able to write to that location unless the root volume has somehow gone read-only or has some other equally serious problem.
Apologies, I should have known that. I am not a linux expert and doing my best, I am also as you can imagine tired/stressed, am very appreciative of your quick responses and assistance in helping me.
