RaymondBailey
Jul 27, 2018Aspirant
Missing /bin folder (ReadyNAS 600 Pro+ RNDP600U)
While connected via ssh and performing an rsync backup I managed to delete the /bin folder on from the device rather than from the external HDD, however the copy on the external HDD is available.
- Aug 15, 2018
Performing the OS reinstall from the boot menu worked, now the admin menu is reporting a drive in predictive failure (it wasn't before and I only knew via email alert). My understanding it that the drive is hot swappable, please correct me if I am wrong as I do have a replacement on hand.
Aug 15, 2018Guru - Experienced User
RaymondBailey wrote:
Have since lost my SSH sessions due to an unexpected reboot and therefore unable to complete your request of generating the os_update file unless there is another way.
mdgm-ntgr also suggested doing an OS reinstall from the boot menu, which should do the same thing. Have you tried that?
RaymondBailey
Aug 15, 2018Aspirant
