JRohde
Oct 08, 2011Aspirant
Missing MySQL extension
Hi I have problems installing both Mysqladmin and Wordpress - they both complain about a missing MySQL extension. As far as I can see, the missing extension is installed, but something is clearly m...
djrikki
Mar 15, 2012Aspirant
Configure PhpMyAdmin:
OK done that, saved twice, same message.
Right... according to this FAQ I need a MySQL Add-On.. I thought this came with the PHP Add-On.
viewtopic.php?f=47&t=22852
Will this work with PhpMyAdmin etc...?
I thought I read somewhere on ReadyNasExtras it doesn't work with 'SuperPoussin's' version.
Allow logins without a password (localhost [1])
You allow for connecting to the server without a password. If you feel this is necessary, use additional protection settings - host authentication settings and trusted proxies list. However, IP-based protection may not be reliable if your IP belongs to an ISP where thousands of users, including you, are connected to.
