longin1
Feb 27, 2015Aspirant
MySQL starting problem - error code: 22002010000
Hi, I have read a few posts about My SQL problem and I haven't found the resolution of my problem. I try to install MySQL from Apps option. Everything is fine - MySQL appears on Installed Apps. ...
Aussiehulk
Feb 16, 2016Aspirant
RN104
Firmware - 6.4.2
MySQL was working perfectly up until last week. After a reboot I get the same error message as the OP. "Application failed initialize, code: 22002010000"
I have tried uninstalling and reinstaling. Rebooted multiple times including after uninstall and then after the reinstall but am gettting nowhere.
Is there a solutions for this?
thank you in advance
