stephanedespres
Aug 02, 2017Aspirant
Netgear Ready NAS NV+
Good day all, I hope you are well! I am facing an issue with our Netgear Ready NAS NV+ Model:RND 4000...I know that this unit may be not supported anymore, but your feedback can help me with the is...
- Aug 02, 2017
stephanedespres wrote:
How can I see if the NIC connection has been disturbed?
The simplest thing is to just remove the ethernet connector and reinsert it.
Or if it is convenient, run another (known good) cable from the NV+ to the upstream switch.
Gigabit requires all 8 contacts to be functioning - if some are open, you can end up negotiating a slower speed. Though usually you'd end up with 100 mbit, not 10.
Aug 02, 2017Guru - Experienced User
I'd wait for the resync to finish, then then power down/restart the NAS.
Maybe also check the NIC connection on the NV+, as it might have been disturbed when you upgraded the disks.
Just in case - you are aware that the NV+ v1 doesn't support drives > 2 TB?
stephanedespres
StephenB -thank you very much for your answer...I'll wait for the sync and restart the unit
Drives that we change are 4x1TB, thanks for the input for maximum capacity (2TB) for each drive on that unit I did not know...
Best regards Stephen!
- StephenBAug 02, 2017Guru - Experienced User
