davidk1952
May 27, 2026Luminary
Netgear RN204 NAS set up and firmware.
I have 2ea RN204 units up and running now and they have been work horse machines... Recently my son in law gave me a unit with out drives he is not using but, no drives... I happen to have 4 WD...
davidk1952
May 29, 2026Luminary
Thanks for the replies Sand-shark and Stephen B, So, yesterday I tried a factory default again and still having an issue.
To answer the question on the static vs DHCP...it is DHCP on the older one and I am assuming this one... .it did give me a IP with the end numbers being .181 For safety this morning I shut down the older one and fired up the new one (The one I just put the drives in) and fired it up... for some reason I am not getting the log in screen and when I put in the Ip address it shows that the device is empty (I think) I tried the Netgear web log in but it comes up with something completely difference and does not have anything about the NAS, I can not get it to the setup page at all. I can not see firmware version.
So since I am paranoid about keeping the original NAS with with lots of files on it... I am trying to be very careful and not wiping it out. I turned off the new unit, unplugged it from the network and turned my original back on.... when it came up it had a new IP address changing from .35 to .48 though.... My Plex server is working and I can get in to the NAS as before so... that is good...but it's strange it gave me another IP address....
So, do you think I should just do a fresh factory install? I have the latest firmware downloaded and unzipped on a flash drive. and I am assuming I'd do that off line with out the Ethernet cable connected....
I'd just like to get this NAS up and running to add to my Plea set up..but I don't want to do anything to disturb my working system that has 10 years of files loaded and running.
Thanks again for the suggestions.
Sandshark
May 29, 2026Sensei
And you are doing the factory default with at least one drive installed? If the drives were used on a machine that uses GPT partitioning, you may need to manually delete the GPT protection partition before the NAS can re-format it.
