tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
JarnoG
Dec 07, 2012Guide
@shaggys: in the settings.json file, there is an option named "umask", set it to 0 and the downloaded files will be read/writable for everyone.
@edmundwatson: Transmission is quite hard on the system resources of the Duo. If options like utp, pex, etc are turned on, it will most likely crash after a while due to this. If you require utp, you can try turning it on and see if Transmission keeps running. You sig says you've upgraded the memory in your Duo, so you should be able to turn a few more features on.
