tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
metosx
Jan 23, 2013Aspirant
Hi and thanks for this release.
So far, no pbms installing it "over the top" of super-poussin's one.
After the installation, I stopped it copy all files from /addons-config/Transmission/transmission-daemon to /addons-config/Transmission then restart.
I get back all settings from previous installation (2.42 by super-poussin).
Otherwise, you stay on port 9091 and download incomplete data to /var/local/Download which is a none writable destination.
Thx again for this add-on.
