tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Feb 21, 2013Tutor
Updated to version 2.77
Changes:
All Platforms
Fix 2.75 regression that broke JSON parsing of real numbers in locales that don't use '.' as a decimal separator
Don't invalidate the OS's file cache when closing files
Fix overflow error when setting speed limits above ~8589 kB/s
Generated magnet links didn't include webseeds
Fix minor memory leaks when using webseeds
Daemon
Fix documentation errors in the spec and manpages
Web Client
Fix minor DOM leak
Changes:
All Platforms
Daemon
Web Client
Fix minor DOM leak
