tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Feb 21, 2013Guide
Just removed super-poussin's 2.42, updated the NV+ firmware to 4.1.10, and installed your 2.77 transmission client. Took me a bit of fiddling to get the download directory and stuff where i wanted it, but that was more on me, then on your piece of kit. So far it looks good, but it will be a while before i can have an opinion on the upload performance. Thank you for your time and effort.
B!
B!
