tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
DiWa
Feb 26, 2013Aspirant
Hi tarobun,
You provide exactly what I was looking for since super-poussin's Duo crashed.
just installed your 2.77 on top of super-poussin's 2.42. Some slight changes:
* json is not at the same place, just moved my existing one. As stated by metosx.
* didn't read "... then remember to save the torrent files somewhere else first." so I lost them, but not a big deal.
Reboot, now it's working fine
some few questions now:
* In your next versions will their be an upgrade process, or the new install will override everything (I'm concerned with settings.json ;) )?
* How can we disable the web interface? I guess it'll be a bit less CPU consumed. I use transmission-remote instead.
Thanks a lot for your very good work.
