tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
Mr_B
Feb 26, 2013Guide
Just don't use it, and it shouldn't affect performance. Admittedly tho, it's just a guess.
DiWa wrote: * How can we disable the web interface? I guess it'll be a bit less CPU consumed. I use transmission-remote instead.
B!
