tarobun
Nov 23, 2012Tutor
New Transmission 2.84 add-on for ReadyNAS Duo/NV+ (sparc)
This is a newly compiled version for the Duo straight from source. It has been configured with "--disable-nls --enable-lightweight --enable-utp" and the default web interface port of 9091. If it do...
tarobun
Mar 02, 2013Tutor
DiWa wrote:
some few questions now:
* In your next versions will their be an upgrade process, or the new install will override everything (I'm concerned with settings.json ;) )?
* How can we disable the web interface? I guess it'll be a bit less CPU consumed. I use transmission-remote instead.
* New versions will upgrade existing install so settings.json will not be lost. I've been upgrading since the first version so can say this works :)
* Not sure about disabling the web interface... Looks like no - "same web server that responds to RPC commands also serves the html/jpg/js/css files for the web server".
